KDE4 гонит на AltLinux'е
Сообщение zaka » 14 апр 2011, 08:58
До сегодняшьнего дня все было нормуль запускаю ОС грузиться нормуль как только я начинаю работать ну типа запускать ПО
все эррор: Процесс: plasma-desktop PID: 7611 Сигнал завершения: Segmentation fault (11)
а вот отчет что делать не наю?
[spoilerОболочка Plasma (plasma-desktop), signal]Application: Оболочка Plasma (plasma-desktop), signal: Segmentation fault
82 T_PSEUDO (SYSCALL_SYMBOL, SYSCALL_NAME, SYSCALL_NARGS)
[Current thread is 1 (Thread 0xb31e29c0 (LWP 7611))]
Thread 3 (Thread 0xab417b70 (LWP 7616)):
#0 0xb768a9fc in __poll (fds=0x8502388, nfds=1, timeout=-1) at ../sysdeps/unix/sysv/linux/poll.c:87
#1 0xb41cb92b in g_poll (fds=0x8502388, nfds=1, timeout=-1) at gpoll.c:132
#2 0xb41badc7 in g_main_context_poll (context=0x84a61e0, block=1, dispatch=1, self=<value optimized out>) at gmain.c:3404
#3 g_main_context_iterate (context=0x84a61e0, block=1, dispatch=1, self=<value optimized out>) at gmain.c:3086
#4 0xb41bb158 in g_main_context_iteration (context=0x84a61e0, may_block=1) at gmain.c:3154
#5 0xb6ab4967 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#6 0xb6a8a529 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#7 0xb6a8a7d2 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#8 0xb69a5f42 in QThread::exec() () from /usr/lib/libQtCore.so.4
#9 0xb6a702fb in ?? () from /usr/lib/libQtCore.so.4
#10 0xb69a8364 in ?? () from /usr/lib/libQtCore.so.4
#11 0xb6936940 in start_thread (arg=0xab417b70) at pthread_create.c:297
#12 0xb76947ce in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:130
Thread 2 (Thread 0xa97a7b70 (LWP 7627)):
#0 pthread_cond_timedwait@@GLIBC_2.3.2 () at ../nptl/sysdeps/unix/sysv/linux/i386/i486/pthread_cond_timedwait.S:180
#1 0xb76a1ce4 in __pthread_cond_timedwait (cond=0x8aab518, mutex=0x8aab500, abstime=0xa97a7200) at forward.c:152
#2 0xb69a893f in QWaitCondition::wait(QMutex*, unsigned long) () from /usr/lib/libQtCore.so.4
#3 0xb699e479 in ?? () from /usr/lib/libQtCore.so.4
#4 0xb69a8364 in ?? () from /usr/lib/libQtCore.so.4
#5 0xb6936940 in start_thread (arg=0xa97a7b70) at pthread_create.c:297
#6 0xb76947ce in clone () at ../sysdeps/unix/sysv/linux/i386/clone.S:130
Thread 1 (Thread 0xb31e29c0 (LWP 7611)):
[KCrash Handler]
#6 0xb0aea031 in TaskManager::TaskItem::task() const () from /usr/lib/libtaskmanager.so.4
#7 0xb0b3b4e4 in ?? () from /usr/lib/kde4/plasma_applet_fancytasks.so
#8 0xb0b3bf3e in ?? () from /usr/lib/kde4/plasma_applet_fancytasks.so
#9 0xb0b34c18 in ?? () from /usr/lib/kde4/plasma_applet_fancytasks.so
#10 0xb0b388a0 in ?? () from /usr/lib/kde4/plasma_applet_fancytasks.so
#11 0xb0b2cb2e in ?? () from /usr/lib/kde4/plasma_applet_fancytasks.so
#12 0xb0b2f55e in ?? () from /usr/lib/kde4/plasma_applet_fancytasks.so
#13 0xb6a90f3e in QMetaObject::metacall(QObject*, QMetaObject::Call, int, void**) () from /usr/lib/libQtCore.so.4
#14 0xb6a9edda in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/libQtCore.so.4
#15 0xb0ae797f in TaskManager::TaskGroup::itemAdded(TaskManager::AbstractGroupableItem*) () from /usr/lib/libtaskmanager.so.4
#16 0xb0ae8b33 in TaskManager::TaskGroup::add(TaskManager::AbstractGroupableItem*) () from /usr/lib/libtaskmanager.so.4
#17 0xb0ad8e3b in ?? () from /usr/lib/libtaskmanager.so.4
#18 0xb0ada6f1 in TaskManager::GroupManager::qt_metacall(QMetaObject::Call, int, void**) () from /usr/lib/libtaskmanager.so.4
#19 0xb6a90f3e in QMetaObject::metacall(QObject*, QMetaObject::Call, int, void**) () from /usr/lib/libQtCore.so.4
#20 0xb6a9edda in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/libQtCore.so.4
#21 0xb0aeab23 in TaskManager::TaskManager::startupAdded(KSharedPtr<TaskManager::Startup>) () from /usr/lib/libtaskmanager.so.4
#22 0xb0aeb096 in TaskManager::TaskManager::gotNewStartup(KStartupInfoId const&, KStartupInfoData const&) () from /usr/lib/libtaskmanager.so.4
#23 0xb0aec291 in TaskManager::TaskManager::qt_metacall(QMetaObject::Call, int, void**) () from /usr/lib/libtaskmanager.so.4
#24 0xb6a90f3e in QMetaObject::metacall(QObject*, QMetaObject::Call, int, void**) () from /usr/lib/libQtCore.so.4
#25 0xb6a9edda in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/libQtCore.so.4
#26 0xb6f1973d in KStartupInfo::gotNewStartup(KStartupInfoId const&, KStartupInfoData const&) () from /usr/lib/libkdeui.so.5
#27 0xb6f1cd10 in KStartupInfo::Private::new_startup_info_internal(KStartupInfoId const&, KStartupInfo::Data&, bool) () from /usr/lib/libkdeui.so.5
#28 0xb6f1ce24 in KStartupInfo::Private::got_startup_info(QString const&, bool) () from /usr/lib/libkdeui.so.5
#29 0xb6f1d0f9 in KStartupInfo::Private::got_message(QString const&) () from /usr/lib/libkdeui.so.5
#30 0xb6f1d208 in KStartupInfo::qt_metacall(QMetaObject::Call, int, void**) () from /usr/lib/libkdeui.so.5
#31 0xb6a90f3e in QMetaObject::metacall(QObject*, QMetaObject::Call, int, void**) () from /usr/lib/libQtCore.so.4
#32 0xb6a9edda in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /usr/lib/libQtCore.so.4
#33 0xb6f65113 in KXMessages::gotMessage(QString const&) () from /usr/lib/libkdeui.so.5
#34 0xb6f655ee in KXMessages::x11Event(_XEvent*) () from /usr/lib/libkdeui.so.5
#35 0xb6f05085 in ?? () from /usr/lib/libkdeui.so.5
#36 0xb6f04ae9 in KApplication::x11EventFilter(_XEvent*) () from /usr/lib/libkdeui.so.5
#37 0xb7769d04 in ?? () from /usr/lib/libkdeinit4_plasma-desktop.so
#38 0xb623bdbc in ?? () from /usr/lib/libQtGui.so.4
#39 0xb6247257 in QApplication::x11ProcessEvent(_XEvent*) () from /usr/lib/libQtGui.so.4
#40 0xb6270672 in ?? () from /usr/lib/libQtGui.so.4
#41 0xb41ba68a in g_main_dispatch (context=0x8088bb8) at gmain.c:2440
#42 g_main_context_dispatch (context=0x8088bb8) at gmain.c:3013
#43 0xb41bae88 in g_main_context_iterate (context=0x8088bb8, block=1, dispatch=1, self=<value optimized out>) at gmain.c:3091
#44 0xb41bb158 in g_main_context_iteration (context=0x8088bb8, may_block=1) at gmain.c:3154
#45 0xb6ab492c in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#46 0xb6270395 in ?? () from /usr/lib/libQtGui.so.4
#47 0xb6a8a529 in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#48 0xb6a8a7d2 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/libQtCore.so.4
#49 0xb6a8e2f7 in QCoreApplication::exec() () from /usr/lib/libQtCore.so.4
#50 0xb61c9837 in QApplication::exec() () from /usr/lib/libQtGui.so.4
#51 0xb77593b3 in kdemain () from /usr/lib/libkdeinit4_plasma-desktop.so
#52 0x080485db in _start ()[/spoiler]
cat /var/log/messages
Apr 14 11:55:29 notebook pulseaudio[7311]: pid.c: Daemon already running.
Apr 14 11:55:30 notebook pulseaudio[7312]: pid.c: Daemon already running.
Apr 14 11:55:30 notebook pulseaudio[7314]: pid.c: Daemon already running.
Apr 14 11:55:42 notebook kernel: [ 953.614570] plasma-desktop[7340]: segfault at 0 ip b0bef842 spf9db464 error 6 in libtaskmanager.so.4.6.0[b0bdc000+31000]
Apr 14 11:56:03 notebook consolehelper[7338]: pam_authenticate failed: Authentication failure
Apr 14 11:56:10 notebook consolehelper[7358]: pam_authenticate failed: Authentication failure
Apr 14 11:56:48 notebook pulseaudio[7678]: pid.c: Daemon already running.
Apr 14 11:56:48 notebook pulseaudio[7282]: module.c: Module "module-device-manager" should be load once at most. Refusing to load.
Apr 14 11:57:08 notebook kernel: [ 1038.800796] plasma-desktop[7717]: segfault at 0 ip b0b45842 spfee7494 error 6 in libtaskmanager.so.4.6.0[b0b32000+31000]
Apr 14 12:01:01 notebook crond[7803]: (root) CMD (run-parts /etc/cron.hourly)
Apr 14 12:07:15 notebook consolehelper[7878]: executing "/usr/sbin/synaptic": (zaka --> root --> rt)
Бытовой хакер
Бытовой хакер
ОС: Maui 2
Re: KDE4 гонит на AltLinux'е
Сообщение ИМХО » 14 апр 2011, 09:54
Попробуй грохнуть настройки plasmы в ~/.kde4. затем перезапустить.
Сообщение zaka » 14 апр 2011, 10:06
ИМХО писал(а):Попробуй грохнуть настройки plasmы в ~/.kde4. затем перезапустить.
так? rm -rf /home/zaka/.kde4/*
уреее все ОК чон-чон рахмат "ИМХО" *OK*
Последний раз редактировалось zaka 15 апр 2011, 08:15, всего редактировалось 3 раза.
Сообщение Infernal Flame » 14 апр 2011, 10:11
zaka писал(а):так rm -rf /home/zaka/.kde4/*?
ога
