PF не открывает 25 порт
robik
Сообщение robik » 25 июл 2011, 11:28
в общем не отдается в мир 25 порт с таким конфигом. если дописываю пасс ани то ани на интерфейсах, не дает результата. сломал голову уже над этой бедой
##Intefaces
wan_if="rl0"
serv_if="rl1"
loc_if="dc0"
##NETWORKS
loc_net="192.168.1.0/24"
serv_net="xx.xx.xx.0/25"
home="{ xx.xx.xx.xx, xx.xx.xx.xx, xx.xx.xx.xx }"
##IP ADDRESSES
squid="xx.xx.xx.xx"
my="xx.xx.xx.xx"
server="xx.xx.xx.xx"
ipod="xx.xx.xx.xx"
mail="xx.xx.xx.xx"
atc="xx.xx.xx.xx"
file_serv="xx.xx.xx.xx"
aster="xx.xx.xx.xx"
toktom="212.42.110.9"
dns_elcat="{ 212.42.96.1, 212.42.96.2}"
soc_found="195.38.189.197"
##PORTS
icmp_types="{ echoreq, unreach}"
aster_ports="{ 22, 5060, 50601}"
chat_ports="{ 443, 5190}"
atc_ports="{ 5103}"
mail_ports="{ 25, 143, 110, 465, 993, 587}"
vnc_ports="{ 5800, 5900}"
toktom_ports="{ 8167, 8168}"
#NAT
nat on $wan_if from $serv_net to any port $chat_ports -> $wan_if
nat on $wan_if from $squid to any -> $wan_if
nat on $wan_if from $mail to any port $mail_ports -> $mail
nat on $wan_if from $mail to any port www -> $mail
nat on $wan_if from $loc_net to any port $chat_ports -> $wan_if
nat on $wan_if from $loc_net to any port $mail_ports -> $wan_if
nat on $wan_if from $my to any -> $my
nat on $wan_if from $loc_net to $soc_found -> $wan_if
nat on $wan_if from $home to any -> $wan_if
nat on $wan_if from $loc_net to any -> $wan_if
nat on $wan_if from $atc to any -> $atc
nat on $serv_if from $serv_net to any -> $serv_if
set skip on lo0
block log all
antispoof log quick for { lo0, $wan_if, $serv_if }
block all
block drop in log quick on { $serv_if, $wan_if, $loc_if } proto tcp from any to any port smtp
block drop log quick from <BRUTEFORCERS>
#Local traffic
pass out on $loc_if from any to $loc_net
pass in  on $loc_if from $loc_net to any
pass out on $serv_if from $loc_net to $serv_net
pass in  on $serv_if from $serv_net to any
pass out on $wan_if from $wan_if to any
pass in on $serv_if from $loc_net to $serv_net
############################SERVERS################################
####################DNS
pass in on $serv_if proto { tcp, udp} to port 53 keep state
pass in on $wan_if proto { tcp, udp} to port 53 keep state
pass out on $serv_if proto { tcp, udp} to port 53 keep state
pass out on $wan_if proto { tcp, udp} to port 53 keep state
#Updates
pass out on $wan_if from any to $soc_found keep state
pass out on $wan_if from any to 65.55.182.108 keep state
pass out on $wan_if from any to 213.199.149.228 keep state
pass out on $wan_if from any to 213.199.149.229 keep state
pass out on $wan_if proto { tcp, udp} from $mail port $toktom_ports keep state
pass in on $wan_if proto { tcp, udp} from $toktom to any port $toktom_ports keep state
pass in on $wan_if from 195.38.189.197 to any keep state
#Asterisk
pass out on $wan_if proto { tcp, udp} from $aster to any port $aster_ports keep state
pass in on $wan_if proto { tcp, udp} from any to $aster port $aster_ports
#Squid
pass out on $wan_if from $squid to any keep state
#MAIL
pass in on $serv_if proto { tcp, udp} from any to $mail port $mail_ports keep state
pass in on $serv_if proto { tcp, udp} from any to $mail port www keep state
pass out on $serv_if proto { tcp, udp} from any to $mail port $mail_ports keep state
pass out on $serv_if proto { tcp, udp} from any to $mail port www keep state
pass in on $wan_if proto { tcp, udp} from any to $mail port $mail_ports keep state
pass in on $wan_if proto { tcp, udp} from any to $mail port www keep state
pass out on $wan_if proto { tcp, udp} from any to $mail port $mail_ports keep state
pass out on $wan_if proto { tcp, udp} from any to $mail port www keep state
#ICMP
pass in on $wan_if proto icmp from any to $wan_if icmp-type $icmp_types keep state
pass in on $wan_if proto icmp from any to $serv_if icmp-type $icmp_types keep state
############################ALL################################
#All in
pass in on $serv_if from any to $my keep state
pass in on $wan_if from any to $my keep state
pass in on $wan_if from any to $atc keep state
pass in on $wan_if from $home to any keep state
#All out
pass out on $serv_if from any to $my keep state
pass out on $wan_if from $my to any keep state
pass out on $wan_if from $atc to any keep state
pass out on $loc_if from any to any keep state
############################Users################################
#USERS IN
pass in on $wan_if proto { tcp, udp} from any to $loc_net port $chat_ports keep state
pass in on $wan_if proto { tcp, udp} from any to $loc_net port $mail_ports keep state
pass in on $wan_if from any to $loc_net keep state
#USERS OUT
pass out on $wan_if proto { tcp, udp} from $loc_net port $chat_ports to any keep state
pass out on $wan_if proto { tcp, udp} from $loc_net port $mail_ports to any keep state
pass out on $wan_if from $loc_net to any keep state
############################Home################################
#Home traffic in
pass in on $serv_if from $home to any keep state
#Home traffic out
pass out on $wan_if from any to $home keep state
pass out on $serv_if from any to $home keep state
Последний раз редактировалось Raven 25 июл 2011, 11:49, всего редактировалось 1 раз.
Причина: Читать правила надо
Re: PF не открывает 25 порт
Сообщение Raven » 25 июл 2011, 11:47
robik писал(а):#NAT
1.эта бойда натит только запросы изнутри наружу
robik писал(а): nat on $wan_if from $mail to any port $mail_ports -> $mail
2. Зачем эта кишка заворачивающая мылсерв на него же?
3. Нигде не вижу проброса портов с внешнего интерфейса на локальный серв.
Попробуй что-то вроде
rdr on $wan_if proto tcp from any to any port $mail_ports -> $mail
З.Ы. Офорляй пожалуйста посты правильно. У нас есть тег code, есть тег bash, да и оверпостниг не особо приветствуется. Свои сообщения можно редактировать)).
robik
Сообщение robik » 25 июл 2011, 11:57
Raven писал(а):1.эта бойда натит только запросы изнутри наружу
не совсем понял. необходимо так же занатить и из вне?
Raven писал(а):2. Зачем эта кишка заворачивающая мылсерв на него же?
хз, только что понял что бред
Raven писал(а):3. Нигде не вижу проброса портов с внешнего интерфейса на локальный серв.
запрос то идет на адрес
robik
Сообщение robik » 25 июл 2011, 12:06
вот конфиг с которым все открывается, описание интерфейсов и потров идентичное первому
#NAT
nat on $wan_if from $serv_net to any port $mail_ports -> $wan_if
#set block-policy return
set skip on lo0
block log all
#scrub in all
antispoof quick for $wan_if
################Rules###################
block all
#Local traffic
####### out
pass out on $wan_if from any to any keep state
pass out on $serv_if  from any to any keep state
pass out on $wan_if proto { tcp, udp} from $mail port www to any keep state
pass out on $wan_if from any to $dns_elcat keep state
pass out on $wan_if from $server to any keep state
pass out on $wan_if from $file_serv to any keep state
pass out on $serv_if from $file_serv to any keep state
pass out on $serv_if from $server to any keep state
pass out on $wan_if proto icmp from $serv_net to any keep state
pass out on $wan_if from any to 195.38.189.197 keep state
pass out on $wan_if from any to 213.199.149.228 keep statepass out on $wan_if from any to 213.199.149.229 keep state
pass out on $wan_if proto { tcp, udp} from $mail port $mail_ports to any keep state
pass out on $wan_if proto { tcp, udp} from any port 53 to any keep state
pass out on $wan_if from $ipod to any keep state
pass out on $wan_if proto { tcp, udp} from any to $toktom port $toktom_ports keep state
####### IN
pass in on $wan_if from $dns_elcat to any keep state
pass in on $wan_if proto icmp from any to $server icmp-type $icmp_types keep state
pass in on $wan_if proto icmp from any to $my icmp-type $icmp_types keep state
pass in on $wan_if proto { tcp, udp} to $mail port www keep state
pass in on $wan_if proto { tcp, udp} to $mail port $mail_ports keep state
pass in on $serv_if from $dns_elcat to any
pass in on $wan_if proto { tcp, udp} from any to any port 53
#USERS
#home traffic
Сообщение Raven » 25 июл 2011, 12:11
robik писал(а):не совсем понял. необходимо так же занатить и из вне?
ну смотри, обьясню на пальцах:
Предположим едешь ты на машине, выехал из гаража, подьехал к пропускной фигне чтоб выехать со стоянки, тебе открывают шлагбаум и ты едешь по делам спокойно. Сделав дела ты возвращаешься назад, а за шлагбаумом нет дороги к твоему гаражу...
robik писал(а):запрос то идет на адрес
Код:$mail
а что у тебя соответствует переменной $mail?
mail="xx.xx.xx.xx"
Сообщение Raven » 25 июл 2011, 12:13
Стоп! У тебя мылсерв тоже на белом ипе?
robik
Сообщение robik » 25 июл 2011, 12:16
Raven писал(а):Стоп! У тебя мылсерв тоже на белом ипе?
ага
mail="212.42.111.***"
Сообщение Raven » 25 июл 2011, 12:30
тогда обрисуй пожалуйста структуру сетки, а то я никак понять не могу зачем с белого ипа натить на белый ип
robik
Сообщение robik » 25 июл 2011, 13:00
тогда так
wan_if= 212.42.96.*
##Intefaces
wan_if="rl0"
serv_if="rl1"
loc_if="dc0"
##NETWORKS
serv_net="212.42.*.*/25"
##IP ADDRESSES
squid="212.42.xx.x"
my="212.42.xx.y"
server="212.42.xx.z"
mail="212.42.xx.q"
file_serv="212.42.xx.t"
aster="212.42.xx.w"
##PORTS
atc_ports="{ 5103}"
конфиг писался экспериментальный, первая моя машинка на никсе, после чего как заработало, я подзабил на это дело, но вот недавно приперло зарезать именно почтарь. оставить только нужное
