отчет dcdiag
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: Default-First-Site\FCS
Starting test: Connectivity
......................... FCS passed test Connectivity
Doing primary tests
Starting test: Replications
[Replications Check,FCS] A recent replication attempt failed:
From USDSERVER to FCS
Naming Context: DC=schloss,DC=ru
The replication generated an error (-2146893022):
Win32 Error -2146893022
The failure occurred at 2012-08-06 16:55.32.
The last success occurred at 2008-05-29 09:44.20.
36720 failures have occurred since the last success.
[USDSERVER] DsBind() failed with error -2146893022,
Win32 Error -2146893022.
From FCOURTT to FCS
The replication generated an error (1396):
Win32 Error 1396
The failure occurred at 2012-08-06 17:30.02.
The last success occurred at 2007-04-06 16:22.17.
464358 failures have occurred since the last success.
Kerberos Error.
The Service Principal Name for FCOURTT.
is not registered at the KDC (usually FCS).
Verify domain partition of KDC is in sync with rest of enterprise.
The tool repadmin/syncall can be used for this purpose.
Naming Context: CN=Configuration,DC=schloss,DC=ru
The last success occurred at 2008-05-29 09:22.38.
From FCOURTT to FCS
Win32 Error 1396
The last success occurred at 2007-04-06 15:58.33.
105832 failures have occurred since the last success.
Kerberos Error.
Naming Context: CN=Schema,CN=Configuration,DC=schloss,DC=ru
The last success occurred at 2008-05-29 08:57.58.
From FCOURTT to FCS
Win32 Error 1396
The last success occurred at 2007-04-06 15:52.31.
46765 failures have occurred since the last success.
Kerberos Error.
......................... FCS passed test Replications
Starting test: NCSecDesc
......................... FCS passed test NCSecDesc
Starting test: NetLogons
......................... FCS passed test NetLogons
Starting test: Advertising
......................... FCS passed test Advertising
Starting test: KnowsOfRoleHolders
......................... FCS passed test KnowsOfRoleHolders
Starting test: RidManager
......................... FCS passed test RidManager
Starting test: MachineAccount
......................... FCS passed test MachineAccount
Starting test: Services
RPCLOCATOR Service is stopped on [FCS]
TrkWks Service is stopped on [FCS]
TrkSvr Service is stopped on [FCS]
......................... FCS failed test Services
Starting test: ObjectsReplicated
......................... FCS passed test ObjectsReplicated
Starting test: frssysvol
There are errors after the SYSVOL has been shared.
The SYSVOL can prevent the AD from starting.
......................... FCS passed test frssysvol
Starting test: kccevent
An Error Event occured. EventID: 0xC000066D
Time Generated: 08/06/2012 17:30:02
(Event String could not be retrieved)
......................... FCS failed test kccevent
Starting test: systemlog
An Error Event occured. EventID: 0x40000004
Time Generated: 08/06/2012 16:38:48
Event String: The kerberos client received a
Time Generated: 08/06/2012 16:55:32
An Error Event occured. EventID: 0x000016AD
Time Generated: 08/06/2012 17:17:39
Event String: The session setup from the computer STRIB failed
An Error Event occured. EventID: 0x00000457
Time Generated: 08/06/2012 17:19:30
Time Generated: 08/06/2012 17:25:35
Time Generated: 08/06/2012 17:28:24
......................... FCS failed test systemlog
Running enterprise tests on : schloss.ru
Starting test: Intersite
......................... schloss.ru passed test Intersite
Starting test: FsmoCheck
......................... schloss.ru passed test FsmoChec
Windows IP Configuration
Host Name . . . . . . . . . . . . : fcs
Primary Dns Suffix . . . . . . . : schloss.ru
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : schloss.ru
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Broadcom NetXtreme Gigabit Ethernet
Physical Address. . . . . . . . . : 00-14-5E-67-80-78
DHCP Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.100.5
Subnet Mask . . . . . . . . . . . : 255.255.255.0
