помогите с BIND9
zubrrr
ОС: suse
Re: помогите с BIND9
Сообщение zubrrr » 16 авг 2012, 10:55
К сожалению, картина не изменилась.
Aug 16 07:42:26 srv named[4548]: zone D.F.IP6.ARPA/IN: zone serial unchanged. zone may fail to transfer to slaves.
Aug 16 07:42:26 srv named[4548]: zone 8.E.F.IP6.ARPA/IN: zone serial unchanged. zone may fail to transfer to slaves.
Aug 16 07:42:26 srv named[4548]: zone 9.E.F.IP6.ARPA/IN: zone serial unchanged. zone may fail to transfer to slaves.
Aug 16 07:42:26 srv named[4548]: zone A.E.F.IP6.ARPA/IN: zone serial unchanged. zone may fail to transfer to slaves.
Aug 16 07:42:26 srv named[4548]: zone B.E.F.IP6.ARPA/IN: zone serial unchanged. zone may fail to transfer to slaves.
Aug 16 07:42:26 srv named[4548]: master/test.local:13: #.test.local: bad owner name (check-names)
Aug 16 07:42:26 srv named[4548]: zone test.local/IN: loading from master file master/test.local failed: bad owner name (check-names)
Aug 16 07:42:26 srv named[4548]: zone test.local/IN: not loaded due to errors.
Aug 16 07:42:26 srv named[4548]: zone 11.3.168.192.in-addr.arpa/IN: loaded serial 45
Aug 16 07:42:26 srv named[4548]: reloading zones succeeded
zubrrr
ОС: suse
Сообщение zubrrr » 16 авг 2012, 10:56
srv:/var/lib/named/master # ls -la /var/lib/named
итого 48
drwxr-xr-x  10 named named 4096 Авг 16 02:47 .
drwxr-xr-x  37 root  root  4096 Авг 16 04:49 ..
-rw-r--r--   1 named named  192 Июл  4  2001 127.0.0.zone
drwxr-xr-x   2 named named 4096 Авг 16 03:36 dev
drwxr-xr-x   2 named named 4096 Фев  2  2012 dyn
drwxr-xr-x   3 named named 4096 Авг 16 07:42 etc
-rw-r--r--   1 named named  158 Июл  4  2001 localhost.zone
drwxr-xr-x   2 named named 4096 Фев  2  2012 log
drwxr-xr-x   2 named named 4096 Авг 16 07:42 master
dr-xr-xr-x 100 root  root     0 Авг 16 03:36 proc
-rw-r--r--   1 named named 2994 Фев  2  2012 root.hint
drwxr-xr-x   2 named named 4096 Фев  2  2012 slave
drwxr-xr-x   4 named named 4096 Авг 16 02:34 var
srv:/var/lib/named/master # ls -la /var/lib/named/master/
итого 16
drwxr-xr-x  2 named named 4096 Авг 16 07:42 .
drwxr-xr-x 10 named named 4096 Авг 16 02:47 ..
-rw-r--r--  1 named named  201 Авг 16 07:41 11-zone
-rw-r--r--  1 named named  267 Авг 16 07:42 test.local
Сообщение Raven » 16 авг 2012, 11:33
Прежде чем скинуть сюда файл зоны вы похоже малость ее вычистили... По крайней мере бинд ругается на закоменченую строку номер 13, а тут ее нет. Запомните простые (элементарные) вещи:
1 - в файлах зон ни в коем случае не должно быть каментов!! Это конечно не запрещено, но бинда их очень не любит!
2 - НИ В КОЕМ СЛУЧАЕ не коментируйте строки в бинде (а уж тем более в зоне) символом '#'!!! Только php-style - '//' или ';'!!!
+ то, из файлов зон, что что я здесь увидел кривовато:
zubrrr писал(а): IN MX 10 srv.test.local
Ничего не смущает, не? точка в конце где? во второй зоне та же ошибка.
Можно конечно добавить в конфиг подгрузки зоны
check-names ignore;
но эт не избавит от кривых зон и прочего гемороя, просто отигнорит ошибки.
zubrrr
ОС: suse
Сообщение zubrrr » 16 авг 2012, 11:43
спс. Очень конструктивная критика.
Да, я то ставил точку то убирал, пробовал по разному.
от этого у меня всегда гемор был, забывал точку в конце.
Про коменты не знал,
Хорошо что есть виртуалка, и есть вы.
Сообщение Raven » 16 авг 2012, 11:48
Завелось?
zubrrr
ОС: suse
Сообщение zubrrr » 16 авг 2012, 11:57
Да, все отлично.
Терь дальше Bind буду достраивать.
Сообщение Raven » 16 авг 2012, 12:01
Ну удачи))) Самое главное - будьте внимательны! Практика показывает, что ~90% всех неприятностей возникают именно по невнимательности. Проблема аналогичная вашей у меня как-то была на продакшне, с > 22к пользователей, а все потому, что напарник правил зоны виндовым блокнотом и использовал табуляцию (тоже очень важный момент - лучше использовать пробелы).
zubrrr
ОС: suse
Сообщение zubrrr » 16 авг 2012, 12:11
Видимо мне пора на ИК, отдых нужен.
